BookmarkSubscribeRSS Feed
adel922
How to make this graph manually (without the use of a JSL script) in Graph Builder?
Dear Community Members,
How can I make the graph in this JMP Community post ( https://community.jmp.com/t5/Discussions/Bar-Graph-and-Line-Graph-overlay/td-p/16529  )  manually (without the use a JSL script) in JMP.
I can make the stacked bar graph.
How can I add the Line(right) tab so that I add the lines to the graph.
Pic2.pngGraph from post
Thank you for your help.
Re: How to make this graph manually (without the use of a JSL script) in Graph Builder?
If you right click on the Y Axis, you will see that you can select "Move Right" and when you select it, you will be able to select what elements you want to move
adel922
Thank you so much.
adel922
Thank you so much.
I clicked on the wrong button.
