BookmarkSubscribeRSS Feed
pmroz
How to make item appear more than once in a List Box?
Hello Jmpers,
Is there a way for a listbox to contain more than a set of unique values? I'm building a listbox in a dialog box and it needs to contain the same value(s) more than once. But it appears that JMP is only displaying the unique values.
Here's some sample code:
style="font-size: 10pt; font-family: "Courier New"; color: black;">separator_list
style="font-size: 10pt; font-family: "Courier New"; color: navy;">=
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"<LF>"
style="font-size: 10pt; font-family: "Courier New"; color: navy;">,
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"/"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"<SPACE>"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"("
style="font-size: 10pt; font-family: "Courier New"; color: purple;">")"
style="font-size: 10pt; font-family: "Courier New"; color: black;">}
style="font-size: 10pt; font-family: "Courier New"; color: navy;">;
style="font-size: 10pt; font-family: "Courier New"; color: black;">tab_dlg
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">NewWindow
style="font-size: 10pt; font-family: "Courier New"; color: black;">(
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Unique
Listbox Values"
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">PanelBox
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Select
Separator"
style="font-size: 10pt; font-family: "Courier New"; color: black;">separator_lb
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">ListBox
width(
style="font-size: 10pt; font-family: "Courier New"; color: teal;">200
style="font-size: 10pt; font-family: "Courier New"; color: black;">)
nLines(
style="font-size: 10pt; font-family: "Courier New"; color: teal;">7
style="font-size: 10pt; font-family: "Courier New"; color: black;">))
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">panelbox
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Action"
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">hlistbox
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">button
box
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Close"
action
style="font-size: 10pt; font-family: "Courier New"; color: teal;">1
style="">
tab_dlg
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><<
close window)
style="">
style="">
style="font-size: 10pt; line-height: 115%; font-family: "Courier New"; color: black;">)
style="font-size: 10pt; line-height: 115%; font-family: "Courier New"; color: navy;">;
Thanks,
Peter
8 REPLIES 8
Re: How to make item appear more than once in a List Box?
Hi Peter
This is curious. I have just written a "get unique values" function because I wanted a list box to contain only unique values from a list.
Display boxes seem to exhibit different behaviour depending on whether they are contained in a modal or non-model window.
Using the Dialog function instead of New Window results in the entire list being shown:
separator_list = {"", "/", "", "(", ")", "", "/", ""};
Dialog(
lb = ListBox(separator_list )
I'm not suggesting that you use a modal window, just pointing out the difference in behaviour.
BTW, how did you retain the formatting of the code in your message ?
pmroz
Curious about modal vs non-modal. Unfortunately I'm stuck with non-modal because of the callback functionality.
To post code retaining formatting is a bit tricky:
1. Copy the code from the JSL editor
2. Paste it into MS Word.
3. Recopy the program text in Word
4. Paste the text into an HTML editor. I use Nvu (http://www.nvu.com/)
5. In Nvu, go to the Source tab and copy the HTML between and
6. Paste the HTML into the JMP discussion forum window.
It sounds more complicated than it is. Worth it for readability. Maybe JMP will update their forum software instead?
Regards,
Peter
pmroz
Hey _Stig_ care to share your function to calculate unique values in a list (not a dataset)?
I.e.
list1 = {"aa", "aa", "aa", "bb", "cc", "cc"};
list2 = get unique values(list1);
print(list2);
{"aa", "bb", "cc"}
Thanks,
Peter
Peter
Here are a couple of implementations:
or :
pmroz
Thanks Stig.  I ended up doing something similar to your first
approach.  I have the luxury of having a sorted list, so it's
a bit faster:
style="font-size: 10pt; font-family: "Courier New"; color: black;">unique_cells
style="font-size: 10pt; font-family: "Courier New"; color: black;">prev_value
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"XyZaBc#$%"
style="font-size: 10pt; font-family: "Courier New"; color: black;">k
style="font-size: 10pt; font-family: "Courier New"; color: teal;">0
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">for
(i
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><=
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">nitems
style="font-size: 10pt; font-family: "Courier New"; color: black;">cell_list)
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;">++,
style="">
one_cell
cell_list[i]
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">if
(one_cell
style="font-size: 10pt; font-family: "Courier New"; color: navy;">!=
prev_value
style="">
prev_value
one_cell
style="">
k
style="font-size: 10pt; font-family: "Courier New"; color: navy;">++;
style="">
unique_cells[k]
one_cell
style="">
Regards,
Peter
aim
aim
Community Trekker
Here is short and fast version:
style="LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt; mso-layout-grid-align: none"
class=MsoNormal>
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt">Get_unique_values
style="FONT-FAMILY: 'Courier New'; COLOR: navy; FONT-SIZE: 10pt">=
style="FONT-FAMILY: 'Courier New'; COLOR: #0000dd; FONT-SIZE: 10pt">Function
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt">(
{in_list}
style="FONT-FAMILY: 'Courier New'; COLOR: navy; FONT-SIZE: 10pt">,
class=MsoNormal>
style="mso-tab-count: 1">
{Default
Local}
class=MsoNormal>
tmp
style="FONT-FAMILY: 'Courier New'; COLOR: navy; FONT-SIZE: 10pt">=>
style="FONT-FAMILY: 'Courier New'; COLOR: teal; FONT-SIZE: 10pt">0
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt">]
style="FONT-FAMILY: 'Courier New'; COLOR: navy; FONT-SIZE: 10pt">;
class=MsoNormal>
style="FONT-FAMILY: 'Courier New'; COLOR: #0000dd; FONT-SIZE: 10pt">Insert
Into
tmp
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt"> in_list
class=MsoNormal>
tmp
style="FONT-FAMILY: 'Courier New'; COLOR: navy; FONT-SIZE: 10pt"><<
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt"> get
keys
class=MsoNormal>
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt">)
class=MsoNormal>
class=MsoNormal>
style="FONT-FAMILY: 'Courier New'; COLOR: green; FONT-SIZE: 10pt">///Example
class=MsoNormal>
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt">try_list
style="FONT-FAMILY: 'Courier New'; COLOR: purple; FONT-SIZE: 10pt">"aaa"
style="FONT-FAMILY: 'Courier New'; COLOR: purple; FONT-SIZE: 10pt">"ss"
style="FONT-FAMILY: 'Courier New'; COLOR: purple; FONT-SIZE: 10pt">"dd"
style="FONT-FAMILY: 'Courier New'; COLOR: black; FONT-SIZE: 10pt">}
class=MsoNormal>
style="FONT-FAMILY: 'Courier New'; COLOR: #0000dd; FONT-SIZE: 10pt">Show
Get_unique_values( try_list ) )
class=MsoNormal>
ms
Super User ms
Amazingly simple solution! Took me a while to figure out how it works. I did not know that the Insert commands were allowed to leave out arguments when applied to associative arrays.
That's a really useful technique. Thanks Aim
