BookmarkSubscribeRSS Feed
isabellet14
Jun 30, 2016
How to make a stacked data table invisible?
I have written a script that stacks some of my data columns and then produces a graph from those stacked columns. I do not want the stacked data table to appear when I run this script, however (I only want the graph) but cannot figure out how to make the new table invisible. For example, if I have the following, is there somewhere I can add in an Invisible parameter so the stacked table doesn't appear? Thanks in advance!
Data Table( "test" ) <<
Stack(
       columns(
               :Name(
                         "example"
               :Name(
                         "example"
Wendy_Murphrey
Jun 23, 2011
Solution
Re: How to make a stacked data table invisible?
The following example demonstrates where the Invisible option can be placed in the Stack():
dt = Open( "$SAMPLE_DATA/Dogs.jmp" );
dt << Stack(
    columns( :LogHist0, :LogHist1, :LogHist3, :LogHist5 ),
    Source Label Column( "Time" ),
    Stacked Data Column( "Log Hist" ), Invisible
Hope this helps.
Wendy
Wendy
ron_horne
Jun 23, 2011
hi isabellet14​,
try this:
//This message applies to all display box objects
dt10 = dt << Stack( columns( :height, :weight ), Source Label Column( "Label" ), Stacked Data Column( "Data" ), invisible );
Distribution(
      SendToByGroup( {:Label == "height"} ),
      Stack( 1 ),
      Continuous Distribution( Column( :Data ), Horizontal Layout( 1 ), Vertical( 0 ), Show Percents( 1 ), Customize Summary Statistics( Sum( 1 ) ) ),
      By( :Label ),
      SendToByGroup(
            {:Label == "height"},
                  Dispatch( {"Distributions Label=height", "Data"}, "Distrib Histogram", FrameBox, {DispatchSeg( Hist Seg( 1 ), Histogram Color( 53 ) )} )
      SendToByGroup(
            {:Label == "weight"},
                  Dispatch( {"Distributions Label=weight", "Data"}, "Distrib Histogram", FrameBox, {DispatchSeg( Hist Seg( 1 ), Histogram Color( 53 ) )} )
isabellet14
Jun 30, 2016
Thanks so much for the prompt help, Ron!
Wendy_Murphrey
Jun 23, 2011
Solution
dt << Stack(
Hope this helps.
Wendy
Wendy
isabellet14
Jun 30, 2016
