BookmarkSubscribeRSS Feed
Jessica1
Community Member
Jun 12, 2018
How to lock a table from a database
Is it possible to lock a table coming from a SQL query?
I've tried just locking the table but I've also tried converting my SQL query into a table and locking it. Neither worked.
Please see red text as example.
Query1=(Open Database("Example Query"));
Query1<<Run Foreground;
Wait(0);
Query1<<Set Edit Lock ("Modify Cells");
<<Make Into Data Table;
Close database connection(Query1)
<< Query1_tabulate=(Tabulate(
Show Chart( 1 ),
Show Control Panel( 0 ),
Add Table(
Column Table( Grouping Columns( :parameter ), Analysis Columns( :value ) ),
Row Table( Grouping Columns( :XX, :YY ) )
 )<< Make Into Data Table;
 Close(Query1_tabulate);
msharp
Jul 28, 2015
Re: How to lock a table from a database
You can lock a table like so:
dt << Lock Data Table( 1 );
// Now try changing a value in the data table.
