gkrjqu7
How to locate "button" from border box/list box?
Hey everyone,
I am new to JSL, and what im trying to do here:
open NEW WINDOW ->
enter item id -> click "OK" button ->
locate that item file (excel)     -> look up the comment in that excel file
However, I am stuck in the early stage to extract TEXT EDIT BOX using button "OK"
I tried google it, but all i could find is using basic modal box.
It would be appreciated if anyone can help:)
Following is the error message:
Cannot subscript Display Box in access or evaluation of 'Subscript' , w[/*###*/"Button"] == 1,
Re: How to locate "button" from border box/list box?
The structure you are following is intended for Modal windows.  Here is an example that I believe is more along the lines you want.  You should really take the time to read the Scripting Guide.
     Help==>Books==>Scripting Guide
w = New Window( "Data and Limits file",
	Border Box( top( 55 ), bottom( 55 ), Left( 66 ), Right( 66 ),
		V List Box(
			H Center Box( Text Box( "Locate item" ) ),
			Spacer Box( size( 1, 11 ) ),
			H List Box( Text Box( "item ID:     " ), D = Text Edit Box( Char( "     6 DIGITS" ) ), ),
			Text Box( "Click SHOW for the ERROR MSG(S)" ),
			Button Box( "OK",
				id = D << get text();
				str = "S:\dir path\" || id || ".xls";
				str_x = "S:\dir path\" || id || ".xlsx";
				If(
					File Exists( str ), Show( "found " || str ),
					File Exists( str_x ), Show( "found  " || str_x ),
					Show( "neither file found" )
				w << close window;
			Spacer Box( size( 1, 33 ) ),
			H Center Box( Text Box( "Error Code | Messages(S)" ) ),
		V List Box(
			Button Box( "OK",
				If(
				w << close window;
gkrjqu7
Will do, thanks for your help.
