BookmarkSubscribe
djhanson
Community Trekker
How to link a Chart display box from report to source dt?
Hi, does anyone know how to link a chart display box from a report located in a new window to the source data table? (e.g. hyperlink it somehow, etc)
Here's what I mean:
myBiv=Bivariate(
     Y( :Y ),
     X( :X ), ....
myReport=myBiv<<report;
new window("MyWin",myReport[outlinebox(1)]);  //create a display box of the chart in the new window
So "MyWin" window displays a chart display box and I'd like to click on it to open up/maximize the original data table (which created the source chart myBiv if that makes sense).  thanks, dj
djhanson
Community Trekker
Re: How to link a Chart display box from report to source dt?
I think what I was looking for was some way to embedd a URL into an object.  I briefly looked into MouseTrap and Handle...but ended up doing a separate ButtonBox("My Window",data table(dt)<<show window(1)) instead.  cheers, dj
ms
Super User ms
An example using mousetrap:
path = "$SAMPLE_DATA/Big Class.jmp";
dt = Open( path );
myBiv = Bivariate( Y( :height ), X( :weight ), );
myReport = myBiv << report;
Eval(
  Parse(
  Eval Insert(
  "myReport[frame box( 1 )] << add graphics script( Mousetrap( Open( \!"^path^\!" ) ))"
New Window( "MyWin", myReport[Outline Box( 1 )] );
Close( dt, No Save );
Clear Globals();
//Click on graph in MyWin to open original table
Is there a reason that you won't simply include the original report in the new window in the first place? For example,
New Window( "My New Window",
     // include report object directly
     Bivariate( Y( :Y ), X( :X ) )
It would have all of the usual live, interactive features.
