wu
wu
How to keep original data type when using Multiple File Import command?
1. when using Open, the data type will be no change
 dt = Open( "$SAMPLE_DATA/Big Class.jmp");
2. But when using Multiple File Import, all column data type change to character type, how to keep the original data type for all columns?
path=Get Path Variable( "SAMPLE_DATA" );
Files=Multiple File Import
<<Set Folder(path),
<<Set Name Filter ("Big*.jmp"),
<<Set Name Enable(1)
)<< Import Data();
Craige_Hales
Staff (Retired)
Re: How to keep original data type when using Multiple File Import command?
I don't think you can avoid the character column issue with Multiple File Import and .jmp files in JMP 14. It is fixed in JMP 15 (future release).
Here's a possible solution.
Craige
