News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
duhamel
How to invoke SOAP web service using JSL ?
Hi everybody,
In order to import data from a distant server to JMP, I have to call a SOAP web service using JSL.
When dealing with RestFul web services, I used to do it with sockets, passing parameters of my request in the URI. But actually, I don't know how to do with SOA web service, as I have an XML to send to the server. I don't even know from where to start.
So please, if anyone could help me sharing a tip or trick about how to use SOAP web service with JMP scripting language, I would really appreciate.
Best reegards,
Jeff_Perkinson
Re: How to invoke SOAP web service using JSL ?
This seems to be a repost of the earlier questionHow to invoke SOAP web service using JSL ?
-Jeff
-Jeff
Eric_Hill
Hey, Duhamel,
JMP does not have any built-in features designed to assist you in invoking a SOAP web service.  I'm not saying it couldn't be done, but I think your efforts would be more fruitful if you used a mechanism other than JMP that is designed to invoke SOAP web services (like a C# program) to invoke your web service and then looked into ways that you might invoke that other mechanism from JSL.
HTH,
Eric
duhamel
Hey Eric,
Thank for your answer I'm gonna see that.
Duhamel
