shaira
How to get rid of extra decimal points during floating point calculations?
I am making a script which takes a matrix as input, gets the interval between the elements in the matrix, and outputs that interval. My problem is that JMP output has extra decimal places sometimes (see log output below). How do I ensure that if my input has N decimal places, output should also have N decimal places?
Script:
outmtx = [0, 0.2, 0.4, 0.6, 0.8, 1, 1.2, 1.4, 1.6, 1.8, 2,
		  2.2, 2.4, 2.6, 2.8, 3, 3.2, 3.4, 3.6, 3.8, 4,
		  4.2, 4.4, 4.6, 4.8, 5, 5.2, 5.4, 5.6, 5.8, 6,
		  6.2, 6.4, 6.6, 6.8, 7, 7.2, 7.4, 7.6, 7.8, 8,
		  8.2, 8.4, 8.6, 8.8, 9, 9.2, 9.4, 9.6, 9.8, 10];
mtxdiff = J(Nrows(outmtx)-1,1,0);
For (i=1, i<=Nrows(outmtx)-1, i++,  mtxdiff[i] = outmtx[i+1]-outmtx[i]);
Show(mtxdiff);
Log window output:
mtxdiff = [0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2,
0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2, 0.2,
0.199999999999999, 0.2, 0.2, 0.2, 0.2, 0.199999999999999, 0.2,
0.2, 0.2, 0.2, 0.199999999999999, 0.2, 0.2, 0.2, 0.2, 0.199999999999999,
0.2, 0.2, 0.199999999999999, 0.200000000000001, 0.199999999999999,
0.200000000000001, 0.199999999999999, 0.199999999999999, 0.200000000000001,
0.199999999999999, 0.200000000000001, 0.199999999999999];
Thanks,
Shaira
Re: How to get rid of extra decimal points during floating point calculations?
See the Round() function. In this case, Round( mtxdiff, 1 ) should do what you want.
