I'm trying to create a master data table that I can then create a subset from that's linked to this original table. I want to be able to add rows to the original data table and have those rows automatically populate into the subset.
However, when I add a row to the original data table, it doesn't appear in the subset that I created and linked. Is this not part of JMP's capabilities? Or am I missing a few steps in order to make this work?
Thanks.
I have had the same problem! I have found that if you add rows of data to your original data set, you also have to add rows to your JMP Data Table before updating using the Tables<Update function. This was driving me crazy for a while until I figured it out. If you simply change existing data and then use the Update function, everything is just fine. appending data is another story until you figure it out.
