Neo
Neo
How to get Repeatability, Reproducibility and Gauge R&R Variation values for each parameter in a table post Gauge R&R analysis via JSL?
I am conducting Gauge R&R analysis for several (~100) measured parameters. My data table with parts, operatorID/Inspector and repeats has spec limits values saved into the measured parameters columns.
Interactively doing the Gauge R&R analysis process as shown at time 1.38 mins as in this video is inefficient and incontinent when the parameters are ~100.
https://community.jmp.com/t5/Statistical-Thinking-for/Conducting-a-Gauge-R-amp-R-Analysis/ta-p/27189...
I would like to automate the process and get the the Repeatability, Reproducibility and Gauge R&R Variation values in a data table.
How to do this via JSL?
Re: How to get Repeatability, Reproducibility and Gauge R&R Variation values for each parameter in a table post Gauge R&R analysis via JSL?
I'm not sure which scripts you are currently talking about. This should use spec limits from column properties (except for the possible bug I did mention earlier which might be present in JMP16)
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
var = dt << Variability Chart(
	Y(:NPN1, :PNP1),
	Model("Main Effect"),
	X(:SITE),
	Historical Sigma(0)
var << "Gauge R&R"n();
If(N Items(var) > 1,
	result_ref = Report(var[1])[OutlineBox("Gauge R&R")];
	result_ref = Report(var)[OutlineBox("Gauge R&R")];
dt_result = result_ref[TableBox(1)] << Make Combined Data Table;
show(Column(dt, "NPN1") << Get Property("Spec Limits"));
show(Column(dt, "PNP1") << Get Property("Spec Limits"));
10 REPLIES 10
There are quite a many ways of doing this, below is fairly simple example of one possible way
	Y(:NPN1, :PNP1, PNP2),
	X(:SITE),
	Variability Analysis(:NPN1, "Gauge R&R Report"n(1)),
	Variability Analysis(:PNP1, "Gauge R&R Report"n(1))
if you have one-sided specifications be sure to check that the variables before and after those work correctly. There was a bug at some JMP version which did use wrong limits if you had one-sided somewhere in between the execution and you relied on spec limits column property (this might be fixed in JMP17, not sure. I use different method nowadays).
Neo
Neo
@jthi Thanks, I have both LSL and USL for each measured parameter.
What you have posted is, if I understand correctly, the initial analysis part.
I want to automate the next stage which is getting the Repeatability, Reproducibility and Gauge R&R Variation values (marked with red arrows) for each measured in a new data table
In the video I linked before, this is done post 1.38 mins into the video and is done manually.
How to automate this part via JSL?
You right click on the Gauge R&R table and create a table from it by using Make Combined Data Table
From the resulting table's table script you can get an idea how to automate it (get a reference to table box and use Make Combined Data Table message)
Start automating with only few columns and when you get it working expand to more.
Neo
Neo
@jthi Thanks. While I wait for understand how to automate this "OK" step for each measured parameter
If I try the following from above in my JM 16.2.0,
	X(:SITE),
Wait (0);
rpt ["Variability Gauge", "Variability Gauge Analysis for PNP1", "Gauge R&R", Table Box[1]] <<Make Combined Data Table;
rpt << Close Window;
I get an error
Name Unresolved: rpt in access or evaluation of 'rpt' , rpt/*###*/
most likely as I haven't defined rpt. The following with script copied from JMP also throws an error
platform = dt << Variability Chart(
	X(:SITE),
Wait (0);
//rpt ["Variability Gauge", "Variability Gauge Analysis for PNP1", "Gauge R&R", Table Box[1]] <<Make Combined Data Table;
//rpt << Close Window;
Report( platform[1] )[Outline Box( "Gauge R&R" )][Table Box( 1 )] <<
Report( platform[1] ) << Close Window;
I need some help to proceed.
I wouldn't worry about getting the table box if you cannot get gage results (worry about table box later). I don't remember anymore how I did gage scripting in earlier JMP versions (JMP14, 15 and 16), but most likely I did them one by one as it most likely faster if you are only interested in the results and not in the plots. This seemed to work in JMP16.2
	Y(:NPN1, :PNP1),
	X(:SITE),
	Historical Sigma(0)
Neo
Neo
@jthi Thanks. This script works in my JMP 16.2 and does not ask me to verify Gauge specifications. Looking at the script for "Make Combined Data Table" for :NPN1, while for I see
platform = Data Table( "Semiconductor Capability" ) <<
Variability Chart(
	Y( :NPN1 ),
	X( :SITE ),
	Model( "Main Effect" ),
	Historical Sigma( 0 ),
	"Gauge R&R"n( 6, 27.48 ),
	"Gauge R&R Report"n( 1 )
Wait( 0 );
while for :PNP1, I see
Variability Chart(
	Y( :PNP1 ),
	X( :SITE ),
	"Gauge R&R"n( 6, 265.26 ),
Wait( 0 );
The question now is how to loop through all the parameters for which GR&R is run and concatenate the "Combined Data Table" generated for each parameter.
Clearly, the spec limits in this line
"Gauge R&R"n( _LSL_, _USL_ )
need to come from the data table for each parameter.
I have never done this but I will try on my side, but some direction would be very useful.
	Y(:NPN1, :PNP1),
	X(:SITE),
	Historical Sigma(0)
Neo
Neo
@jthi In this code, how to correctly loop through all the measured variables (~100) in my data table?
	X(:SITE),
Build list of columns of interest and then send Gauge R&R Report message
	Y(:NPN1, :PNP1),
	X(:SITE)
var << "Gauge R&R Report"n(1);
