MathStatChem
How to get R standard output
When I submit R Code via JSL, the R console standard output (stdout) displays in the JMP log.  Is there a way to capture that information in a text string?  I know I can redirect the stdout from R to a file (using the sink() function) and then get the file contents in a JMP variable with some JSL, but I'd rather not have to use an intermediate step like that.
Example;
names default to here(1);
R Init();
dt=open("$SAMPLE_DATA/Cars.jmp");
R Send(dt);
R Submit(
	summary(lm(formula=Chest.decel ~ Wt, data=dt))
RTerm();
This output shows in the log file
Call:
lm(formula = Chest.decel ~ Wt, data = dt)
Residuals:
    Min      1Q  Median      3Q     Max
-17.931  -6.650  -1.482   5.593  44.232
Coefficients:
             Estimate Std. Error t value Pr(>|t|)
(Intercept) 3.853e+01  2.440e+00  15.792  < 2e-16 ***
Wt          3.354e-03  8.135e-04   4.123  4.7e-05 ***
Signif. codes:  0 '***' 0.001 '**' 0.01 '*' 0.05 '.' 0.1 ' ' 1
Residual standard error: 9.367 on 339 degrees of freedom
  (11 observations deleted due to missingness)
Multiple R-squared:  0.04776,	Adjusted R-squared:  0.04495
F-statistic:    17 on 1 and 339 DF,  p-value: 4.703e-05
I want to be able to get the output as a text string and put that into a Text Box in a report window.
ms
Super User (Alumni) ms
Re: How to get R standard output
 Log Capture() may do what you want.
R Init();
dt = Open("$SAMPLE_DATA/Cars.jmp");
R Send(dt);
R_stdout = Log Capture(R Submit("
R Term();
New Window("example", Text Box(R_stdout));
uday_guntupalli
Level VIII
@MathStatChem ,
      Before I go too far ahead, are you not wanting to use R Get() ? Did you try using R Get() and then using that information as input to the text box ?
Best
Uday
MathStatChem
From what I can see, R Get() will get the values from an R data structure or variable (number, string, matrix, list, or data frame), but not the standard output.
uday_guntupalli
Level VIII
@MathStatChem ,
Try this:
R Init();
R Send(dt);
R Submit(
	model = lm(Chest.decel ~ Wt,data = dt)
	t = summary(model)
	# Use names function to determine what are the objects that exist
	names(t)
	# Extract and cast into data frames
	Residuals = as.data.frame(t$residuals)
	Coefficients = as.data.frame(t$coefficients)
ResidJMP = R Get(Residuals);
ResidJMP << New Data View;
CoeffJMP = R Get(Coefficients);
CoeffJMP << New Data View;
RTerm();
Close(dt,"No Save");
Best
Uday
MathStatChem
Thanks for the suggestion.   I know if I can put the R results into a R data object, then I can use R Get() to retrieve the results.  However, it would be a lot easier to just get the stdout results as a text string, at least for my purposes.
@uday_guntupalli wrote:
@MathStatChem ,
Try this:
R Init();
R Send(dt);
R Submit(
	t = summary(model)
	names(t)
RTerm();
ms
R Init();
R Send(dt);
R Term();
