How to extract the value color column property and store in a list?
shaira_narido
May 4, 2017
I want to get the color assigned to a specific cell, assuming that the cell column has "value color" property.
Here is the copy of my script that was applied to Big Class.jmp. I added value color property to "sex" column.
//Get the grouping column and store in a list
Summarize( A = by( :sex ) );
B = :sex << get property( value ordering );
If( Is Empty( B ),
	GroupList = A,
	GroupList = B
Show( GroupList );
//get the value color ordering property
GroupColor=:sex << get property( value colors );
Show(GroupColor);
The output is as follows:
GroupList = {"F", "M"};
GroupColor = {"F" = 19, "M" = 21};
However, I want the output for the GroupColor to be like this:
GroupColor = {19,  21};
Is this possible?Thanks,
Shaira
ian_jmp
Jun 23, 2011
Solution
NamesDefaultToHere(1);
:sex << Set Property( "Value Colors", {"F" = -13647958, "M" = -4222675} );
groupColor = :sex << get property( value colors );
Show(groupColor);
for(i=1, i<=NItems(groupColor), i++,
	groupColor[i] = Arg(groupColor[i], 2);
Show(groupColor);
Jun 22, 2012
Solution
This will work
For( i = 1, i <= N Items( GroupColor ), i++,
	GroupColor[i] = Num( Word( 3, Char( GroupColor[i] ) ) )
ian_jmp
Jun 23, 2011
Solution
Show(groupColor);
Show(groupColor);
shaira_narido
May 4, 2017
Thanks! This works. :)
Jun 22, 2012
Solution
This will work
shaira_narido
May 4, 2017
Thanks! This also works. :)
