eadekanmbi
How to extract realtime data from constant-changing database using JSL
I have a database that keep updating itself every 2 hours and I want to find a way to get the updated table without having to keep going to the database to obtain new tables each time the database is updated. Please, how do I about this in JMP?
Re: How to extract realtime data from constant-changing database using JSL
Pour intérroger les données il faut soumettre une requête SQL.
Hormis requêter la table toutes les 2 heures pour avoir les dernières données fraîches, je ne vois pas trop comment faire.
Craige_Hales
Staff (Retired)
If there are time stamps, the query might only need to fetch data more recent than the last time.
Craige
Yes, one solution could be to :
 - query the table (SQL)
 - save the data into jmp datatable
 - keep the max(timestamp) and store it into jmp table for example
Next query :
 - query the table (SQL) from max(timestamp) to now()
 - then concatenate to previous data extraction
Then loop :)
