lwx228
How to express the Summary Statistics amount in the "table" with variables?
I need to pick your brain again:
Take this picture alone.The red box is where the number of columns is variable.
For the convenience of description, column 4 is used as the Group.
Column variables starting and ending in column 5 are the values requiring Summary.
How are the column names in the red boxes represented in the form of variables?
Thanks you!
dt = Open( "$SAMPLE_DATA/Boston Housing.jmp" );
lwx228
Re: How to express the Summary Statistics amount in the "table" with variables?
The following code was provided by Jim when I consulted with the decision tree example.
But I don't know how to apply this to Summary.
Thank you!
colNamesList = dt << get column names;
xFactorList = As List( colNamesList[5 :: N Items( colNamesList )] );
Partition(……,X( Eval( xFactorList ) ),……
lwx228
I can only do variable form in this way at the moment.Thank you!
