BookmarkSubscribeRSS Feed
todds
Oct 23, 2012
How to evaluate a matrix on the fly?
I am sure there is a simple answer to this problem but I can't figure it out.  I am trying to compute distance between two objects using a distance matrix.  I can't get the following JSL code to work:
dt = Open (dist matrix.jmp);
m = dt << Get All Columns As Matrix();
dt2 = Open(students.jmp);
col = Column("Prefect No");
B=col<<Getasmatrix;
n=nrow(dt2);
a=j(n,1,0);
for(i=1,i<=n, i++, a=m[b,4]);
show(a);
I keep getting an error when evaluating m[,].  I tried Eval and other things but it doesn work.
Can anyone help?
todds
Oct 23, 2012
Re: How to evaluate a matrix on the fly?
I figured out what the main error was.  Some of the rows had missing values and when JMP tried to evaluate the missing subscript it bombed.  So I used the following code:
for(i=1,i<=n, i++, if((not(is missing(A[i]))), C[i]=m[A[i],8], C[i]=.));
It works fine.
Now my only issue is that when I use
The subsequent matrix m is not in the order that I have it in the dataset.  So trying to figure out how to keep the original order.  Any ideas?
mikedriscoll
Jun 23, 2011
Got an example data set? I had one and tried the following code, and it had the correct order.  It replaced character values with '1's though, which is along the lines of what I'd expect.
dt = current data table();
show(m);
todds
Oct 23, 2012
I saved my dataset back to excel and brought it back into JMP.  Now that dataset when is made into a matrix is in the correct order.  I must have reset the default order of the columns when I recreated it in JMP.  So now everything works.  Thanks for the help.
