Ted
Ted
How to edit Graph Builder gird line?
Pls, see the attached picture.
P.S. Just in case -- it's empty in script window here:
Graphics area => Customize => Plus => script window.
Thank you in advance. (JMP 13line.jpg)
stan_koprowski
Re: How to make vertical gird Graph Builder own line more thicker and black?
Hi @Ted,
Two ways to modify the graph spacing line--
  1. Right-click on the line and select graph spacing and set to a value of 10.
  2. Under the red-triangle select graph spacing and set to a value of 10.
stan_koprowski
Hi @Ted,
Ted
Ted
Re: How to edit Graph Builder gird line?
Oh! Thank You, Stan, for so clear explanation!
