a01
a01
How to do "row-number-over"?
In a JMP table, what is the best-known method for doing the equivalent of ROW_NUMBER ( ) OVER ( [ PARTITION BY value_expression , ... [ n ] ] ORDER BY ...) that we can do in SQL (such as Transact-SQL)?
For the T-SQL version see: https://msdn.microsoft.com/en-us/library/ms186734.aspx
If I have this example table:
NameFood
AliceToast
BobOrange
AliceApple
CharliePizza
BobTomato
And I want to add an "instance number" column that gives me the instance of that person based on an alphabetical sorting on Food...
Name
FoodInstance
AliceToast2
BobOrange1
AliceApple1
CharliePizza1
BobTomato2
(Order of the output table doesn't matter.)
A method I found so far is to sort the input table by (Name, Food) and add a formula column:
If(Row() == 1, 1, If(Lag(:Name, 1) == :Name, Lag(:Instance, 1) + 1, 1))
Is this the easiest way to mimic the ROW_NUMBER SQL function, or does JMP offer a more convenient way?
XanGregg
Re: How to do "row-number-over"?
The closest thing I can think of is Col Rank(), but it doesn't currently support BY variables or character columns.
