How to do Bankers Rounding in JMP
nathan-clark
Sep 27, 2016
I was recently asked about banker's rounding and didn't find anything in the JMP documentation. I wrote the quick function below (as well as a formula option), but was curious if 1) JMP has a canned method for doing banker's rounding and 2) what other/better methods may be useful vs. mine. http://wiki.c2.com/?BankersRounding
bankerRound = Function( {inputValue},
	{inputValue, fDiff, cDiff, modX, bankRound},
	fDiff = inputValue - Floor( inputValue );
	cDiff = Ceiling( inputValue ) - inputValue;
	modX = Modulo( Round( inputValue, 0 ), 2 );
	If(
		cDiff == fDiff & modX == 0, bankRound = Ceiling( inputValue ),
		cDiff == fDiff & modX != 0, bankRound = Floor( inputValue ),
		bankRound = Round( inputValue, 0 )
	Return( bankRound );
inputValue = Empty(); // put column name here
If(
ih
Sep 30, 2016
Solution
It is not built in but I think this accomplishes the same thing:
	if(	mod(inputValue, 0.5) == 0 & ! mod(inputValue, 1) == 0,
		round(inputValue / 2) * 2,
		round(inputValue)
tests = { 0,0.499,0.5,0.501,1,1.499,1.5,1.501,2,2.499,
	2.5,2.501,3,3.499,3.5,3.501,-0.499,-0.5,-0.501,
	-1,-1.499,-1.5,-1.501,-2,-3};
for( i = 1, i <= N items( tests ), i++,
	Write( char( tests[i] ) || " -> " ||
		char( bankerRound( tests[i] ) ) || "\!N" );
nathan-clark
Sep 27, 2016
Ok, that looked horrible.... let's try this for the two formula options:
bankerRound = Function({inputValue},
    {inputValue,fDiff,cDiff,modX,bankRound},
    fDiff = inputValue - floor(inputValue);
    cDiff = ceiling(inputValue) - inputValue;
    modX = Modulo(round(inputValue,0),2);
    if(cDiff == fDiff & modX == 0,
        bankRound = Ceiling(inputValue)
        bankRound = Floor(inputValue);
        bankRound = Round(inputValue,0);
    Return(bankRound)
inputValue = Empty(); // place column name here
ih
Sep 30, 2016
Solution
		round(inputValue)
nathan-clark
Sep 27, 2016
That does look like a cleaner solution. Too bad JMP doesn't have this as a canned rounding thing. To be honest, I had no idea there were other kinds of rounding than ... standard? rounding :)
Thanks!
