BookmarkSubscribe
robot
How to determine if a JMP journal is already opened?
I have a script in which the user will have the option of running an analysis multiple times.  The script will create a journal of the results.  However, I would like the script to create a new journal the first time it is run, but add results to the existing journal when the script is run subsequently.  Is there a way to determine if a specific (or any) journal is already open in JMP?
I found a way to determine if a data table is already opened (), but I have not gotten it to work for a journal.  Any advice?
Thanks!
ms
Super User ms
Re: How to determine if a JMP journal is already opened?
There are probably several ways to do this. Here is one idea that seems to work (tested in JMP 10).
//Function to test if a specific journal exists
Already_there = Function( {jname},
  n = N Items( Window() );
  If( jname == Current Journal() << get window title, // If no journal is open Current Journal() will open one
  Print( "Journal exists" )
  If( N Items( Window() ) - n == 1,
  Current Journal() << close window); // Close the redundant journal if created
  Print( "There is no such journal" );
//Test of function
j_title = "Test";
my_journal = Current Journal(); // Example journal
my_journal << set window title( j_title );
Already_there( j_title );
my_journal << close window; // Close example journal
ms
Super User ms
//Test of function
j_title = "Test";
robot
Works great!  Thanks!
