Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
plkx
How to create summary stats table with original columns and stats in rows?
This seems like it should be trivial, but I've not found a way to accomplish the goal (so far - I'm relatively new to JMP but have spent significant time looking for this).
I have a large data table with 1779 columns, the first of which contains substance names, and the remaining 1778 (variables) contain numeric data for continuous modeling.
I need summary stats in a table that mirrors the columns in the original table, with the first column containing rows of the various summary stats (let's say these: N, N missing, min, max, range, median, mean, geometric mean, variance and standard deviation).
I want to use the summary stats to pick variables from the original columns (and to remove irrelevant variables altogether).
It seems silly to resort to Excel (which I don't totally trust for stats), only to transfer it all back to JMP, to Fit Y by X, etc.
Thanks,
PL
plkx
Re: How to create summary stats table with original columns and stats in rows?
Apparently, I just needed to reveal my ignorance before I was able to do this using tabulate by dragging each stat.
It would be nice to just have check boxes, or choose stats by highlighting them.
At least I can now move on...
plkx
