BookmarkSubscribe
bwanders
How to create conditional formula for costs with categorical ingredients
I have attached an example mixture design with one categorical factor for one of the ingredients.  How would I create a formula to compute the total cost of the formula when it depends on which type of ingredient is used?
If X1 is type A, the total cost is $1/kg x % X1 + $0.50/kg x % X2 + $0.75/kg x X3
If X2 is type B, the total cost is $2/kg x % X1 + $0.50/kg x % X2 + $0.75/kg x X3
If X3 is type C, the total cost is $3/kg x % X1 + $0.50/kg x % X2 + $0.75/kg x X3
Then I would be able to use the prediction formula for targeted costs.
bwanders
Re: How to create conditional formula for costs with categorical ingredients
Thank you, Karen.
KarenC
There is a matching formula in JMP that would work great if you are looking at 3 formulas based on X1 Type (which is what your table suggests but not your post).
Copy and paste this into a column formula:
Match(:X1 Type, "A", :X1 + 0.5 * :X2 + 0.75 * :X3, "B", 2 * :X1 + 0.5 * :X2 + 0.75 * :X3, "C", 3 * :X1 + 0.5 * :X2 + 0.75 * :X3, Empty(), Empty())
bwanders
Thank you, Karen.
