mdeng
How to create a workflow that can run a set of analyses for multiple files in one folder
I would like to use a workflow to run the same set of analyses on multiple .csv files saved in a folder.
I know how to create a workflow for a specific .csv file, but I don't know how to create a workflow to run the set of analyses on a list of .csv files. My JSL skill is limited.
I appreciate your help.
Margaret
Re: How to create a workflow that can run a set of analyses for multiple files in one folder
You didn't select source for the for each (you have to tell it to use the Group you created earlier)
You can also rename the group (and you should) by changing the step name of the group
6 REPLIES 6
Workflows do have For Each (in JMP18) which you might be able to utilize
Or maybe you could add all your results into same table using Multiple File Import WITH the file name. Then perform your analysis using filename column as By column in the JMP platform.
mdeng
Hi Jarmo,
Can you create a simple example by showing how to use For Each? I tried it and didn't get any success.
Example:
Open two files
Create two analyses that will be performed for each file.
Thanks
Margaret
Open tables and group them
Run analysis on one table and group it to for each
Use group defined first as source for for each group
Seemed to work but I'm not sure if this is the way how these should be used as I don't really like using workflows
mdeng
Hi Jarmo,
I tried your recommendation and created the workflow above. The workflow opened all three files. Then, it stopped and asked me to select a file to run the control chart. Any other recommendations?
Thank you so much!
Margaret
mdeng
Yeah, it worked!
Jarmo, thank you so much! :)
