BookmarkSubscribeRSS Feed
mujahida
Jan 11, 2014
How to create a file which is created by save as: interactive with html and data
I have tried to create a file by file>save as> "interactive with htm and data"from JMP 11, but I failed to open it.
so I have two question:
1. does it mean  " Internet Explorer"  which is built in my computer is not IE9.0 or better?
2. What kinds of report can be created in "interactive with htm and data"?
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: How to create a file which is created by save as: interactive with html and data
I'm sorry that you're having trouble.
Can you tell us what happened when you tried to open the html file you saved?
The interactive html that JMP 11 saves was tested with IE 9.0 and IE 10. We can't guarantee that everything will work in earlier versions of IE but it should open at lest.
Almost any report can be saved as interactive html and will have some interactive elements. Not every display element is implemented in this form in JMP 11 but lots of them are. You can learn more about it here.
-Jeff
-Jeff
