BookmarkSubscribeRSS Feed
robust1972
Community Trekker
How to control bubble size with script in JMP13?
With below script, I was able to draw a wafer map with bubble plot in JMP12. The bubble size was set as 35 to represent a die. But in JMP13, the bubble size went to smallest even when same script and same preference setting are used.
Bubble Plot(
	X( :X ),
	Y( :Y ),
	Coloring( :Vmin ),
	Bubble Size( 37 ),
	Size as Sum( 0 ),
	Color as Sum( 1 ),
	Label( "All" ),
	Set Shape( "Square" ),
	Color Theme( "Green Yellow Red" ),
	Color Levels( [0.44 0.605 0.77 0.935 1.1] ),
	Fit to Window( "Off" ),
	Title Position( 0, 0 ));
Re: How to control bubble size with script in JMP13?
Thank you for reporting this - It appears that the Bubble Size() is not working as an argument to Bubble Plot(), but it does work if you send a message after the platform is created:
bp=BubblePlot(...);
bp << Bubble Size(37);
This issue will be fixed in a future release.
bp=BubblePlot(...);
