BookmarkSubscribeRSS Feed
volf
Staff (Retired)
Jun 23, 2011
How to contain image in JMP Window
Hi Jmpers,
I'm going to make a message box window through JSL.
Do you know How to contain image in JMP Window?
Image format is jpg, png, gif and so on.
regard.
matthewh
Jun 23, 2011
Re: How to contain image in JMP Window
I would also like to do this - specifically incorporating an image file (png, jpg etc) into a Journal that is generated using a JSL script. Is it possible? The journal then gets exported as HTML so the image would need to be kept in this export.
Thanks,
Matthew.
ms
Jun 23, 2011
This blog entry (see link below) discusses the topic somewhat. It appears that it is not possible to insert an existing image by jsl-script in JMP 8, but JMP 9 may see some improvements in this area according to he author.
Apparently an image can be dropped or pasted into a JMP window (however, it does not seem to work on the Mac, I just get the file's icon embedded instead of its image).
Of course an image can be drawn from scratch using jsl but I guess that's not what you are after.
http://blogs.sas.com/jmp/index.php?/archives/220-Vector-Plots-in-JMP.html#comments
matthewh
Jun 23, 2011
OK, thanks for your reply!
