JMP is taking Discovery online, April 16 and 18. Register today and join us for interactive sessions featuring popular presentation topics, networking, and discussions with the experts.
shmuel_bron
How to close multiple JMP data tables without saving?
JMP11 makes it practically impossible to close many data tables at once. Even if clearly stated that I am not interested in saving any of them ("Save none") JMP 11 takes you to a save-as screen.
This is highly detrimental to work efficiency.
Is there a trick/tip to make JMP11 work similarly with JMP9 in that respect.
Thnx!
Sam
12 REPLIES 12
shmuel_bron
Re: How to close multiple JMP11 data tables?
Martin, I am sorry to say but the problem is NOT solved.
I thought it was but it isn’t. I don’t know why sometimes it works and sometimes it doesn’t but this is …life.
I tried also the escape “trick” suggested by Craige (Thnx a lot!) but it didn’t work either.
Meanwhile the only thing working for sure is the add-in.
Rgds and thanks to all!
I hope JMP12 will behave better.
Sam
Shmuel Bron
Yield Analyst
0879310301
SamH
hi everyone, is there a way to close multiple data tables using script?
the multiple data tables are generated during a script I generated to create analysis and produce a final chart wind/jnr.
Thanks
Sam
Craige_Hales
When you see this behavior, JMP might be running a script with wait() statements that allow some commands to partially work while the script is running.  Try pressing Escape and check the log to see if a script stopped.
dt=open("$sample_data\big class.jmp");
dt:name[1] = "x";
while(1, wait()); // terrible programming technique
Craige
