BookmarkSubscribeRSS Feed
Laura
Community Trekker
Oct 4, 2017
How to automatically run a script every time and input is changed
I have created a script and I'd need JMP automatically running it everytime a value of a column is modified instead of having to manually run it. Does anyone know how to do this?
Thanks a lot in advance!
Laura
markbailey
Jun 23, 2011
Re: How to automatically run a script every time and input is changed
You might be able to use a handler. See Help > Scripting Guide > Objects > Data Table > Make Row State Handler.
ian_jmp
Jun 23, 2011
Depending on the details, you might also find 'Subscribe()' useful (st the same path Mark gives above).
