LarsBirger
How to analyze the numerical order of repetetive values in rows?
I am one of the few persons in Sweden who uses JMP whereas most of my academic collegues use SPSS. However, I love JMP and have published 70 articles in surgery with it so it works fine with for me. I am Associate Professor and would describe myself as an advanced JMP amateur that can programme somewhat however there is one issue that I am having problems with. I have posted this question previously but did not exactly understand the answers on the forum. The problem is as follows:
I have a file called Results.
In this file I have a column of 5700 numbers that are sorted in order like:
Nr
3456
3666
3687
3687
3687
5444
5444
5445
I would appreciate information on how I should write a script or if I should write anything in an extra column in order to get the order of repetetive appearances of the numbers. The reason is that I am only interested in the first nr. and if I can get the order I could make a separate file consisting of only order 1.
like
Nr         Order
3456     1
3666     1
3687     1
3687     2
3687     3
5444     1
5444     2
5445     1
Since I am an amateur I would appreciate if you could write the answer in a simple way.
Sincerely yours
Lars Enochsson
Associate Professor
Umeå University
Sweden
gzmorgan0
Re: How to analyze the numerical order of repetetive values in rows?
Since the column Nr is in sorted order, ths can be done with a column formula. Before presenting the formula, you should look into Main Menu > Help > Scripting Index > Functions > Row or search for Lag.  I created a column called Count and added this formula.  By default the first row has a count of 1.  The second condition :Nr == Lag( :Nr, 1) is the condition, if the current row is equal to the previous row, then take the previous count, Lag( :Count, 1 ) and increment it.  Otherwise, the count is 1.
If(
	Row() == 1, 1,
	:Nr == Lag( :Nr, 1 ), Lag( :Count, 1 ) + 1,
	1
image.pngNote JMP Lag works on text as well as numbers.  However, if I had a column of text, I'd recommend modifying the function to be
If(
	Row() == 1, 1,
	Trim( Lowercase( :txtCol ) ) == Trim( Lowercase (Lag( :txtCol, 1 ) ) ) , Lag( :Count, 1 ) + 1,
	1
 Hope that helps.
gzmorgan0
If(
	Row() == 1, 1,
	1
If(
	Row() == 1, 1,
	1
 Hope that helps.
LarsBirger
Thanks. Excellent help. This solved the problem./Lars
ms
Super User ms
Try a column formula with the Col Rank() function with a by-variable It may require JMP 13 or later, not sure when support for by-variables in ColRank first was introduced.
Try the script below. It should give the same result as the previous solution. However, it does not depend on sorting.
Current Data Table() << New Column("Order", Formula(Col Rank(:Nr, :Nr)));
(Yet another JMP user in Sweden)
gzmorgan0
Sweet!  ColRank() with a by variable was not available until JMP 13.
As an FYI, here is a script to check performance.  If there were 1,000,000 or more rows, I'd probably sort and use lags.
Names Default to Here(1);
dt = New Table("Test It", add rows(6000),
	New Column("Nr", numeric, continuous,<<set each value(Random Integer(1,2500)) )
t0 = hptime();
dt << New Column("Count", <<Formula(ColRank(:Nr, :Nr)));
t1 = hptime();
dt:Count << delete formula;
t2 = hptime();
dt << Sort( By(:Nr), Order( Ascending ), Replace Table);
t3 = hptime();
t4 = hptime();
dt << New Column("Count2", <<Formula(If(
	Row() == 1, 1,
	1
t5 = hptime();
show(t1-t0, t3-t2, t5-t4); //Col Rank(), Sort(), using Lag()
 For 6000 rows, using Col Rank() =  3.13*using lags
    t1 - t0 = 18836;
    t3 - t2 = 1863;
    t5 - t4 = 4161;
For 1,000,000 rows, using Col Rank() =  2.45*using lags
    t1 - t0 = 1521679;
    t3 - t2 = 694813;
    t5 - t4 = 621142;
