BookmarkSubscribe
romrigal0
Community Trekker
How to add several ColList in the same windows
I'd like to create a window selecting parameters from differents tables. I use journal and scripts for this.
The best I can do for this, is opening a new window for each table.
choix1 =Column Dialog(
  current data table(dt_fil_step_1);
  selection_step_1 = colList( "Paramètres à représenter", maxcol( N Col(dt_fil_step_1)) ),
  current data table(dt_fil_step_2);
  selection_step_2 = colList( "Paramètres à représenter", maxcol( N Col(dt_fil_step_2) ) ),
  current data table(dt_fil_step_3);
  selection_step_3 = colList( "Paramètres à représenter", maxcol( N Col(dt_fil_step_3) ) );
Actually the window should look like this :
Re: How to add several ColList in the same windows
To start with, you do not want to use a Column Dialog().  That methodology is being de-emphasized in JMP.  Below is the beginning of a script that will do what you want.  You will need to fill in the code you need to populate the Parameters Selected list, etc. but it does popup the 3 data tables for you to select from.
dt_fil_step_1 = Open( "$SAMPLE_DATA/big class.jmp" );
dt_fil_step_2 = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
dt_fil_step_3 = Open( "$SAMPLE_DATA/drug measurements.jmp" );
selected list = {};
choix1 = New Window( "test",
       Lineup Box( N Col( 2 ),
                     Current Data Table( dt_fil_step_1 );
                     selection_step_1 = Col List Box( dt_fil_step_1, all );,
                     step_1_BB = Button Box( "Select for Data Table 1" ),
                     Current Data Table( dt_fil_step_2 );
                     selection_step_2 = Col List Box( dt_fil_step_2, all );,
                     step_2_BB = Button Box( "Select for Data Table 2" ),
                     Current Data Table( dt_fil_step_3 );
                     selection_step_3 = Col List Box( dt_fil_step_3, all );,
                     step_3_BB = Button Box( "Select for Data Table 3" )
              selected list = List Box( selected list, nlines( 22 ) )
Phil_Brown
The ButtonBoxes would then need their click action defined, for example:
step_1_BB <<Script(selected list << Append( selection_step_1 << GetSelected ));
PDB
romrigal0
Community Trekker
Thanks a lot it's running well.
