tim_reeves
How to add an interactive Color by Column selection to Graph Builder?
I have a script (in JMP 16.2) that creates a Graph Builder with a column switcher, and I want to add a feature to allow selecting (interactively or up front) a column (or columns) by which to color the points. I've searched and not found an example.
tim_reeves
Re: How to add an interactive Color by Column selection to Graph Builder?
 I should add that I have well over 100 columns and I want to choose the columns to color by from a small subset
ian_jmp
Level X
Not quite sure what you have in mind, but this may get you started:
NamesDefaultToHere(1);
nw = NewWindow("Color",
		clb = ColListBox(all, << ModelingType({"Nominal", "Ordinal"}), maxSelected(1)),
		LineUpBox(NCol(2),
			ButtonBox("OK", OKscript),
			ButtonBox("Cancel", nw << closeWindow)
OKscript =
Expr(
nw << closeWindow;
colorCol = clb << getSelected;
gb = dt << Graph Builder(
					Show Control Panel( 0 ),
					Variables( Y( :height ), Color( Eval(colorCol)) ),
					Elements( Points( Y, Legend( 7 ) ) ),
					Column Switcher( :height, {:height, :weight} )
