lwx228
How to achieve automatic batch replacement with JSL?
This table is generated dynamically by the JSL running process. How to use the JSL automatic implementation to replace the 0 value starting from column 2 of this table with a null value "" ?
JSL is required to be replaced with a list of column Numbers or dynamic names.
Either a column - by - column replacement or a one-time replacement.
Re: How to achieve automatic batch replacement with JSL?
I cannot test this script but it should work.
Names Default to Here( 1 );
// assume that data table is open
dt = Current Data Table();
For( c = 2, c <= N Cols( dt ), c++,
	target row = dt << Get Rows Where( Column( dt, c )[] == 0 );
	If( N Rows( target row ) > 0,
		For( r = 1, r <= N Rows( target row ), r++,
			Column( dt, c )[target row[r]] = .;
9 REPLIES 9
lwx228
Upload a data file, Ask the experts for help.Thank you very much!
lwx228
I was careless. I used the grammar of VBA directly and forgot to use "Empty()".
MichelleG
I don't know if this is the most computationally-efficient way of doing this -- in fact, I assume it's not. But if you need a quick brute-force solution, this has worked for me in the past: loop over the columns, then loop over the rows looking for the value you want to replace, setting the new value as you find it.
dt = current data table();
colnames = dt << Get Column Names(String);
for(c=2,c<=N Items(colnames),c++, // starting at 2 per your note
	For Each Row(
		If(column(dt,colnames[c])[]==0, // if you find a 0
			column(dt,colnames[c])[]=Empty() // make it empty
MichelleG
Nice, this cuts down on the number of rows to loop over, saving time on big tables. I was thinking there might be a way to use the Recode functionality on the table as a whole, but I see you've (@markbailey) already explained elsewhere that this is an interactive editor, not a JSL function.
Such processing will be even easier and faster in JMP 15. You will be able assign the missing value to all the rows in one call.
Wait( 1 );
// create 5 observations of zero
n = N Row( dt );
For( i = 1, i < 6, i++,
	r = Random Integer( 1, n );
	:weight[r] = 0;
	:height[r] = 0;
Wait( 1 );
For( c = 4, c <= N Cols( dt ), c++,
		Column( dt, c )[target row] = .;
lwx228
I'm really looking forward to using JMP 15.Thank you very much!
pmroz
The syntax:
already works in JMP 14.
lwx228
  • Thank you very much!
    • I have used the following code before:
    For( i = 3, i <= N Col( d2 ), i++,
    	As Column( i )[d2 << get rows where( As Column( i ) == 0 )] = Empty()
