The World Statistics Day celebration continues here in the Community. We all need reliable data for sound decision making. Do you have a data source that you trust most? Head over to Discussions to tell us about it.
uday_guntupalli
Level VIII
Re: How to Separate Matching Values in a List
@Jaz,
      This is an alternative approach, with the use of Loc().
MyList = {22,33,22,22,22,33,33,44,44,44,33,22};
AA = Associative Array(MyList);
UniqueVals = AA << Get Keys;
Frequency = {};
for(i = 1, i <= N Items(UniqueVals),i++,
		Insert Into(Frequency,N Rows(Loc(MyList,UniqueVals[i])));
Show(Frequency);
Best
Uday
Jaz
Jaz
Hi @pmroz,
I tried the first solution you posted and it works fine with one file / list. But when I use your code as a function and loop through it, (despite having initialised all my variables to make sure that nothing from the previous iteration stored) it doesn't seem to be working. I'm referencing to a file because I loop through a column in the file to get the list being used. Any ideas on what's going on as I've made sure to initialise all the lists and variables?
pmroz
Can you post some data and code?
Jaz
Jaz
No worries, I solved the ssue and your solution wasn't part of the problem. Thanks.
pmroz
If you're looping through a column in a file why not just use the Tabulate or Summary commands?   If you are grouping things by another column you can use that as a "by" variable.  For example:
ID Value
A 1
A 2
A 2
B 2
B 3
B 3
B 4
B 4
Using tabulate drag the ID and Value columns over the drop zone for rows.  You'll need to change the role of Value to be a grouping variable.  This is the result:
ID Value N
A 1 1
A 2 2
B 2 1
B 3 2
B 4 2
So for A you have two distinct values (1, 2), along with the number of occurrences (1, 2).  For B you have three distinct values (2, 3, 4), along with occurrences (1, 2, 2).
Here's the equivalent JSL:
dt = New Table( "Test", Add Rows( 8 ),
		New Column( "ID", Character, "Nominal",
		Set Values( {"A", "A", "A", "B", "B", "B", "B", "B"} ) ),
	New Column( "Value", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [1, 2, 2, 2, 3, 3, 4, 4] ) )
dtab = dt << Tabulate(
	Add Table( Row Table( Grouping Columns( :ID, :Value ) ) ),
	invisible
dt2 = dtab << Make Into Data Table;
vince_faller
I'm a big fan of design.
names default to here(1);
l = {22, 22, 22, 33, 33};
l = sort ascending(l);
d = VSuM(design(l));
csum = cumulative sum(d);
lvalues = l[csum];
aa = associative array(lvalues, d);
*Edit* I realized that sorting was taking a lot of time so this is a lot faster
my_list = {44, 33, 22, 33, 44};
aa = associative array(my_list );
keys = aa << Get Keys;
d = design(my_list , keys);
aa_design = associative array(keys, VSum(d));
*Edit again (don't know why this is bothering me so much)* I didn't like the associative array and this is faster still
d = design(my_bigger_list, <<Levels);
aa_design = associative array(d[2], VSum(d[1]));
Vince Faller - Predictum
I believe your last edit needs to have the "my_bigger_list" changed to "my_list"
Article Labels
