Jaz
Jaz
Community Trekker
How to Separate Matching Values in a List
I have a list which could contain the following, for example: {22, 22, 22, 33, 33}. I want to be able to get the number of each unique value in the list, e.g. the number of 22's and the number of 33's. The problem is, I don't know how long my list will be and how many unique numbers there will be in the list. Is there any way in JSL to generalise a solution for this?
Thanks
pmroz
Re: How to Separate Matching Values in a List
Table operations are probably the fastest way to do this.
my_list = {22, 22, 22, 33, 33};
dt = New Table( "Untitled", invisible, Add Rows( nitems(my_list) ),
	New Column( "Column 1", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( my_list )
dtab = dt << Tabulate(Show Control Panel( 0 ),
	Add Table( Row Table( Grouping Columns( :Column 1 ) ) ));
dt2 = dtab << Make Into Data Table(invisible);
unique_value_list = dt2:column 1 << get values;
unique_count      = dt2:n << get values;
close(dt, nosave);
close(dt2, nosave);
show(unique_value_list, unique_count);
16 REPLIES 16
Jaz
Jaz
Community Trekker
I've managed to get a list of the unique values like so {22, 33} using associative arrays and the << get key functionality but I still don't know how to get the number of each of those unique values in the original list.
pmroz
close(dt, nosave);
close(dt2, nosave);
Here is my variation on @pmroz solution.  It is more of an old school solution
	private,
	Add Rows( N Items( my_list ) ),
		Numeric,
		"Continuous",
// Use the Summary Platform to create the aggragate values
dtSum = dt << Summary(
	private,
	Group( :Column 1 ),
	Freq( "None" ),
	Weight( "None" )
// Create the new lists
unique_value_list = As List( dtSum:column 1 << get values );
unique_count = As List( dtSum:n rows << get values );
Close( dt, nosave );
Close( dtSum, nosave );
Show( unique_value_list, unique_count );
pmroz
Don't forget summarize.  Even shorter.
summarize(dt, unique_value_list = by(:column1), unique_count = count(:column 1) );
vince_faller
@pmroz's response got me interested.  Because I usually try to avoid data tables if I can just because of the overhead.  I played with timings
names default to here(1);
my_list = {44, 33, 22, 33, 44};
repeat_list = [1, 5, 10, 50, 100, 1000,  2500, 5000, 7500, 10000];
dt_timing = new table("Timings",
	new column("List Size"),
	new column("Design"),
	new column("Loop"),
	new column("Summarize"),
for(ii=1, ii<=20, ii++,
	for(ir = 1, ir <= nitems(repeat_list), ir++,
		my_bigger_list = repeat(my_list, repeat_list[ir]);
		// using design
		st = HPTime();
		aa = associative array(my_bigger_list);
		keys = aa << Get Keys;
		d = design(my_bigger_list, keys);
		aa_design = associative array(keys, VSum(d));
		time_design = HPTime() - st;
		//using a loop
		st = HPTime();
		aa_loop = associative array(my_bigger_list, repeat(0, nitems(my_bigger_list)));
		for(i=1, i<=nitems(my_bigger_list), i++,
			aa_loop[my_bigger_list[i]]++;
		time_loop = HPTime() - st;
		//using a data table
		st = HPTime();
		dt = New Table( "Untitled", invisible, Add Rows( nitems(my_bigger_list) ),
				Set Values( my_bigger_list )
		close(dt, nosave);
		aa_peter = associative array(unique_value_list, unique_count);
		time_peter = HPTime()-st;
		Eval(EvalExpr(
			dt_timing << Add Rows({List Size = Expr(Nitems(my_bigger_list)), Design = Expr(time_design), Loop = Expr(time_loop), Summarize = Expr(time_peter)});
dt_stack = dt_timing << Stack(
	columns( :Design, :Loop, :Summarize ),
	Source Label Column( "Method" ),
	Stacked Data Column( "Timing" )
close(dt_timing, no save);
biv = dt_stack << Bivariate(
	Y( :Timing ),
	X( :List Size ),
	group by(:Method),
	fit line(),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Row Legend(
				Method,
and obviously it depends on the list size.  But I ran it 20 times each on various list sizes and got this
Design was the fastest way I could find to do it.  And I definitely agree with @txnelson that I don't like Summarize because of it returning character always.
Vince Faller - Predictum
Jeff_Perkinson
I agree with @pmroz and @txnelson, data tables make this easy.
I prefer the Summarize() function over Tabulate and Summary for this though.
	private,
		Numeric,
		"Continuous",
summarize(dt, group=by(:column 1), n=count(:column 1));
show(group, n);
-Jeff
My support for the Summary Platform, is that the grouping variable is maintained as the same Data Type in the summary data table as it was in the originating data table.  In the Summarize() function, it is always returned as character values, even if the By column specified was numeric.
Jaz
Jaz
Community Trekker
Thanks,
Would be useful if JMP included a find matching items / return matching items function for lists / associative arrays as they do for columns & rows.
Please post this suggestion in the Wish List area of the Community.
