ZZHAO
New Contributor
How to Join tables
I have 2 JMP tables I want to join them. In each tables, I have exclueded and hided a few rows. When I did join, the excluded/hided rows were showing in the joined table, which is something I don't want. Does anyone know how to join 2 tables and do not include the excluded rows?
Thank you so much in advance.
Zhengxin
Re: How to Join tables
The way to do this is to subset the data tables prior to joining them, first selecting all of the rows that have not been hidden and/or excluded. Then join the subsetted tables.
ZZHAO
New Contributor
Thank you for the responce. Yes, this work-around works. However, it will just make the header name longer after join due to subset is added to filename of subsetted tables
in your subset request, you can set the name of the new output data table
