We’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
ram
ram
How to - Graph label inside the graph?
How to bring the spec Label inside the graph?
As in picture below, Label is outside the graph area. how i can bring the Label inside the Graph. Like Ticks can be inside or outside. similarlar option for Labels--- i am looking for.
Thank you for any help.
lLimit = 55; uLimit = 70; tLimit = 62.5;
Eval(Eval Expr(
		:height << Set Property(	"Spec Limits",
			{LSL( Expr( lLimit ) ), USL( Expr( uLimit ) ), Target( Expr( tLimit ) ),			Show Limits( 1 )}
Spec label is outside the graph area.Spec label is outside the graph area.
Re: How to - Graph label inside the graph?
your request can only be done by adding a script to the graph, to generate your own text and line using JMP graphic functions.  There is not an option to have the spec limit labels be displayed within the frame of the graph.
ram
ram
Hi Tx,
That is not a good option in my opinion. e.g in the Bivariate plot if you add label using graphic script, Y lable moves when you adjust the scale of x-axis and vice- versa. that looks very bad that label are far from the axis. I guess JMP team have to provide a real solution.
Thanks
Ram
