1cooldudeme
How to Fit Y by X where Variables Cycle Through Certain Columns?
Hello everyone,
I am trying to figure out how to Fit Y by X, where Y cycles through all of my Numerical-Continuous columns ending in "_CODED" that have been produced earlier in the script. After every column has been used as Y for the first X, I'd like to have the next "_CODED" column be used as a new X, and have the Y columns be cycled through again, until all possible graphs have been produced, preferably in a single window instead of separate windows.
I am having trouble using a variable for the CODED columns in the Bivariate portion of the script, which is what I think I need to do, but everything I've tried so far has produced errors. Could someone look through what I have and try to help me with this?
dt = Data Table("data.jmp");
cols = dt << get column names(Character); //List all character columns
For (i = 1, i <= N Items(cols), i++,
     one_col   = cols << get name;
     coded_col = one_col || "_CODED";
     col_expr = evalinsert(
"\[   dt << New Column("^coded_col^", Numeric, "Continuous",
Format("Best", 12), Formula(
                if (:name("^one_col^") == "PASS", 1,
                     :name("^one_col^") == "FAIL", 2,
                     :name("^one_col^") == "", 3,
                     :name("^one_col^") == "NOTTESTED", 4,
                     :name("^one_col^") == "IGNORE", 5,
                     :name("^one_col^") == "PASS|PASS", 6,
                     :name("^one_col^") == "IGNORE|IGNORE", 7,
                     :name("^one_col^") == "NOTTESTED|NOTTESTED", 8;
eval(parse(col_expr))
//That was all to produce new Numerical-Continuous columns out of the columns I have. Continuing the script, I am trying to create Y by X graphs of these new columns. I'm actually not quite sure what to do here..
Bivariate(
  Y( (coded_col),
  X( (coded_col),
  Fit Line( {Line Color( {213, 72, 87} )} )
ian_jmp
Re: How to Fit Y by X where Variables Cycle Through Certain Columns?
Not sure I understood your intention exactly, but FYI, you can do this kind of thing:
NamesDefaultToHere(1);
// Sample Data
dt = NewTable("Data",
NewColumn("Not X", Numeric, Continuous, Formula(RandomInteger(0, 3))),
NewColumn("Not Y", Numeric, Continuous, Formula(RandomInteger(0, 3))),
AddRows(20);
For(c=1, c<=5, c++,
dt << NewColumn("VAR"||Char(c)||"_CODED", Numeric, Continuous, Formula(RandomNormal()));
// Get all the columns in the table dt . . .
cols = dt << getColumnNames("String");
// Retain only the columns we want
For(c=NItems(cols), c>=1, c--,
If(!EndsWith(cols[c], "_CODED"), RemoveFrom(cols, c));
// Launch the platform (makes 5 x 5 = 25 plots)
biv = dt << FitYByX(X(Eval(cols)), Y(Eval(cols)));
