BookmarkSubscribeRSS Feed
mujahida
Jan 11, 2014
How to Create a Map
How to create a Map?
I have had a study on JMP help about how to create Map by graph builder,
such as GongDong province, China.
I found these data related to create Map such name data and
coordinate data as below; and I paste them into windows: C:\Program
Files\SAS\JMP\10\Maps
After that, I use the name data sheet and drag the column of
NAME2004 into shape zone, I failed to create that map.
Based on above scenario, experts, who can guide me out of this
trouble? Thanks you not enough!
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: How to Create a Map
I think my paper from SAS Global Forum a couple of years ago might help clear things up.
Here's a link.
Create Compelling Visualizations with Geographic Data and JMP® 9
While it references JMP 9, the techniques are the same for JMP 10 and JMP 11.
I'm also attaching the PDF.
-Jeff
-Jeff
