How to correctly convert a column into date and time elements? For example, in the following JSL, the original data is "20230507G10:11:59". How can I convert the data type into a numeric date format like "YYYY-MM-DD H:M:S", such as "2023-05-07 10:11:59"?
dt = New Table( "Untitled");
New Column( "Original setting" );
:Original setting << Data Type( Character );
:Original setting << Set Values( {"20230507G10:11:59", "20230912G11:14:50", "20241211G15:21:14"} );
New Column( "Date format" );
:Date format<< Data Type( Character );
:Date format << Set Values( {"20230507G10:11:59", "20230912G11:14:50", "20241211G15:21:14"});
Column( dt, "Date format" ) << Format( "yyyy-mm-dd" );
