Luggilas
How should the formula for this regression look?
I am currently writing my bachelor thesis and am not that experienced in JMP or regression in general. I was wondering how the formula for the attached regression would look? I know you can make a predection expression but I need to set it up in more general terms.
Like: beta0+beta1*X1+beta2*X2
I hope it makes sense and that someone can help.
Ressel
Re: How should the formula for this regression look?
Intuitively, I think you need to look into dummy variables: https://en.wikipedia.org/wiki/Dummy_variable_(statistics)
In the journal you shared, there is a nice big window showing the prediction expression. You have two questions with 3-4 possible responses (from multiple choice?). Possibly, each response can be represented with its own dummy variable. How to write that in general terms is perhaps only another Google search away.
Good luck with your thesis!
MRB3855
Hi @Luggilas ; As @Ressel said, you will need to define several indicator ("dummy") variables; based on your Prediction Expression in your output, something like below:
5.8708 + 1.703*I11 -0.946*I12 -0.757*I13 -0.358*I21 +3.591*I22 + 1.611*I23 -4.844*I24
Where I11 = 1 if Questions 1 (Hvor ofte…) = Dag, 0 otherwise.
I12 = 1 if Question 1 (Hvor ofte…) =Mindre, 0 otherwise.
Etc.
