Amy1
How does JMP treat replicates if it is not specified in model?
Hi all,
I did an experiment with 2 by 3 factorial design of treatments, so there are 6 treatment combinations total. Each treatment combination has 4 replicates. In model, I only specified the treatment effects and their interactions, and did not specify replicates as random effect. JMP still took average of the replicates. I wonder how JMP treated the replicate since it was not specified. Do I have to rerun the analysis with replicate as random effect?
Thank you very much!
Amy
Re: How does JMP treat replicates if it is not specified in model?
I assume that JMP is adding the replicates to the calculations for the appropriate other effects in the model, and the replicate effects will be added to the error(non model) effect.
Article Labels
