deb
deb
How do you write JSL script to handle JMP alert with stepwise fit?
I have a JSL script that loops through over 100 least squared fits with personality stepwise.  Most of the models are created without a problem, but a few encounter 'Stepwise is cycling'.
The log shows the following until I escape out.
'Stepwise is cycling.  Continue?
Reset cycle counts?
Reset cycle counts?'
etc..
How would I script a response to 'cancel' if this JMP Alert is triggered?  my jsl lines in the for loop are below.
current data table(dt);
y=expr(y());
Ef=expr(Effects());
insert into (y, :column(i));
insert into (ef, varexpr);
obj=expr(Fit model());
insert into (obj, nameexpr(y));
insert into (obj, nameexpr(ef));
insert into (obj, nameexpr(st));
insert into (obj, nameexpr(rn));
fit= obj<<finish;
sm = fit << Make Model;
fit2 = sm << Run Model;
