Pat23
How do i do Iteration Analysis
Hi
Could someone point in the right direction, I have completed a Gage R&R, completed 3 test runs on the same device. When I analyse the results the Failures are mostly on the third run using alll the same inputs,  were in jmp stastically will it tell me that the number of tests on the same device is having an impact my results.
Thanks,
Pat.
Pat23
Re: How do i do Iteration Analysis
See attachment
Standard
0 = Fail (Red) should Fail
1 = Pass (Green) Should Pass
