lwx228
How do code JSL to run the text directly to the table?
See the image.Thank you very much!
d2 = Current Data Table();
aaa = d2[1, 1];
dt << New Column( "test", formula( aaa ) );
dt << run formulas;
Re: How do code JSL to run the text directly to the table?
Here are 2 ways to do this........I am sure others also exist
d2 = Data Table( "Formula Table" );
aaa = d2[1, 1];
Eval(
	Substitute(
			Expr(
				dt << New Column( "test", formula( __formula__ ) );
				dt << run formulas;
		Expr( __formula__ ), Parse( aaa )
aaa = d2[1, 1];
Eval( Parse( "dt << New Column( \!"test\!", formula( " || aaa || " ) );" ) );
dt << run formulas;
aaa = d2[1, 1];
Eval(
	Substitute(
			Expr(
				dt << run formulas;
aaa = d2[1, 1];
dt << run formulas;
lwx228
I really appreciate Jim.You taught me a lot.Thank you very much!
