caspears
How do I write a formula to population Column B based on a partial string in Column A?
For example:
Column A has
University of Hawaii
Hawaii Community College
Column B is currently blank, it is new.  I want to populate it based on Column A's data.
For example...
If Row A has a string with "University" in it then I want Row B to say "University"
If Row A has a string with "Community" in it, then I want Row B to print "Community"
and I want this to happen for every instance of University or Community.
uday_guntupalli
Level VIII
Re: How do I write a formula to population Column B based on a partial string in Column A?
@caspears ,
       The script I provided had multiple portions .
        Portion 1 :
             Create a new table with sample data to demonstrate
        Portion 2 :
             Actual formula that you seek
         In your case , you essentially only need the part in the Formula
dt = New Table();  // Create a new table - you dont need this
dt << New Column("Col1",Character,Continuous,<< Set Values({"University of Toronoto","Community College of Tempe","Temple University","Arizona University","Community College of Wisconsin"})); // Create a column with sample data for demo - you dont need this
DesList = {"University","university","Community","Community"}; // you actually dont need this
dt << New Column("Check",Character,Continuous,Formula(If(!IsMissing(Regex(Char(:Col1),".*[uU]niversity*")),
																"University";
														If(!IsMissing(Regex(Char(:Col1),".*[cC]ommunity*")),
																"Community";
				); // In this part of the script all you need is the part under "Formula"
Here is the part you need.  You can't use :Col1 in this. It needs to be replaced by the Column you are performing the search on
	"University";
	"Community"
Best
Uday
uday_guntupalli
Level VIII
@caspears
        You can use Contains() or Regex() to do this . I will provide an example with Regex()
dt = New Table();
																"University";
																"Community";
For a little more explanation on "Regular Expressions" - look here - https://community.jmp.com/t5/Discussions/Regex-help/m-p/48759#M27716
or follow Craige Hales blog here (https://community.jmp.com/t5/Uncharted/Regex/ba-p/21008/jump-to/first-unread-message )
Best
Uday
caspears
Hi:
It's not doing anything:
uday_guntupalli
Level VIII
@caspears ,
        Portion 1 :
        Portion 2 :
																"University";
																"Community";
	"University";
	"Community"
Best
Uday
I believe this formula is a simpler version of what @uday_guntupalli was suggesting
If(Contains( UpperCase( :Column A, "UNIVERSITY" ), "University",
     Contains( UpperCase( :Column A, "COMMUNITY" ), "Community"
caspears
It worked thanks a lot!
