lwx228
How do I use JSL to control the bulk import of each column data format of TXT text?
Dear all:
There are multiple TXT format table data in the same path, but I only import one file into JMP at a time.
Since each TXT file has different column names and number of columns, how to use JSL to unify the data to be imported from column 8 to the last column to be set to consecutive number format?Thank you very much!
lwx228
Re: How do I use JSL to control the bulk import of each column data format of TXT text?
I think this way of recording with JMP is too complicated.
I would suggest that you try just using the Open() function with just the path as input.  That way, JMP will use the defaults, and examine the file and open the table.  You can then use your JSL to determine what has been input, and to modify the data table down to what you need.
lwx228
Well, that's all. Thank you very much!
The actual data of my TXT file are all over 600 columns, some of which may have a lot of null values. JMP automatically determines that these columns are in text format, and as a result, these columns do not have data import, which is troublesome to deal with.
I would like a bit more detail on what you mean by "troublesome".  Having JMP parse across a data table with lots of blank columns, and determining which ones to delete, etc. ia a relatively easy thing to do.  So in the past, I have typically taken this approach.
lwx228
This allows me to write the JSL way of importing files in a one-to-one way, which gives me more open() code.A single file has 50, 000 characters of open() code.
