AN
AN
How do I search for a parameter failing test specs?
Re: How do I search for a parameter failing test specs?
If you are dealing with a large dataset, I'd try using the Process Screening Platform in JMP 13.  You could also use the Process Capability Platform directly.  You can learn about both of these in the books provided with JMP under Help > Books.  For Process Screening, you want Predictive and Specialized Modeling. For Capability Analysis, you want the Quality and Process Methods text.
Best,
M
Best,
M
