lwx228
How do I replace auto-generated parameters with custom color parameters in a Bubble Plot?
Dt = Open (" $SAMPLE_DATA \ World Demographics. The JMP ");
Hide the first row and delete the first five columns with "(1000)" in the column name.
Generate the Bubble Plot with the following code.
dt = Current Data Table();
c11 = Quantile( 1, (:Crude Birth Rate << get values) ) * 1.01;
c12 = Quantile( 0, (:Crude Birth Rate << get values) ) * 0.99;
c21 = Quantile( 1, (:Crude Death Rate << get values) ) * 1.01;
c22 = Quantile( 0, (:Crude Death Rate << get values) ) * 0.99;
c31 = Quantile( 1, (:Population << get values) );
c32 = Quantile( 0, (:Population << get values) );
pa = {0.05, 0.275, 0.5, 0.725, 0.95};
xF = {};
For( c = 1, c <= 5, c++,
	na = Quantile( pa[c], (:Infant Mortality Rate << get values) );
	Insert Into( xF, na );
Bubble Plot(
	X( :Crude Birth Rate ),
	Y( :Crude Death Rate ),
	Sizes( :Population ),
	Coloring( :Infant Mortality Rate ),
	ID( :Territory ),
	Color Levels( xF ),
	Title Position( 0, 0 ),
		Dispatch( {}, "1", ScaleBox, {Format( "Best", 10 ), Min( c12 ), Max( c11 ), Inc( 5 ), Minor Ticks( 1 )} ),
		Dispatch( {}, "2", ScaleBox, {Format( "Best", 12 ), Min( c22 ), Max( c21 ), Inc( 5 ), Minor Ticks( 0 )} )
Wait( 0 );
The parameter JSL code automatically generated by the software is
Color Levels([2.31 46.785 91.26 135.735 180.21])
How do I write JSL if I want to use my own parameters instead?
Thanks!
Re: How do I replace auto-generated parameters with custom color parameters in a Bubble Plot?
The JMP Scripting Guide has a good overview of using matrices in JSL.  If you already have a list, you can convert it to a matrix:
Create a column vector from a single list:
A = Matrix( {1, 2, 3} );
[1,2,3]
You can also create an empty matrix and build it up by concatenation, similar to how you were using the list:
cl = [];
cl = cl || 100000;
cl = cl || 150000000;
cl = cl || 300000000;
cl = cl || 450000000;
cl = cl || 600000000;
[100000 150000000 300000000 450000000 600000000]
When you know the size of the matrix ahead of time, you can create the full matrix and use subscripts to assign values:
cl = J(1,5);
cl[1] = 100000;
cl[2] = 150000000;
cl[3] = 300000000;
cl[4] = 450000000;
cl[5] = 600000000;
Show(cl);
cl = [100000 150000000 300000000 450000000 600000000];
Hope that helps!
The argument to Color Levels() must be a matrix - the list argument will be ignored.  Here's an example that works:
dt = Open( "$SAMPLE_DATA/PopAgeGroup.jmp" );
obj = Bubble Plot(
	X( :Name( "Portion 0-19" ) ),
	Y( :Name( "Portion60+" ) ),
	Sizes( :Pop ),
	Coloring( :Pop ),
	ID( :Country ),
	Color Levels( cl )
lwx228
Thank danschikore!
Now the focus is on how to change xf into a matrix form, and I've searched and still can't find the answer.Ask for help.
I tried to write code like this, but it didn't work。Thanks!
Mat = Number Col Box("",xf) << get as matrix;
Color Levels( Mat ),
[1,2,3]
cl = [];
cl = cl || 100000;
cl = J(1,5);
cl[1] = 100000;
cl[2] = 150000000;
cl[3] = 300000000;
cl[4] = 450000000;
cl[5] = 600000000;
Show(cl);
Hope that helps!
