Kelly
How do I prevent JMP Alerts from popping up?
When I use a combo button on the dashboard I get a JMP Alert. Nevermind what the alert says because it runs smoothly besides the popup. Is there a way to prevent or close that Alert within the script?
I have tried:
Combo11 << Batch Interactive ( 1 );
throw();
stop();
Thanks for the help!
vince_faller
Re: How do I prevent JMP Alerts from popping up?
Don't send batch interactive to the combobox, you just put the environment into batch interactive when you run your script.
Names default to here(1);
new window("Example",
	combobox({"Thing 1", "Thing 2", "Thing 3"},
		<<Set Function(
			Function({self, value},
				print(value);
				if( value == 2,
					throw("This should throw a popup")
				, //elif
					value == 3,
					batch Interactive(1);
					throw("This should throw to log");
					batch Interactive(0);
Vince Faller - Predictum
vince_faller
		<<Set Function(
				print(value);
				if( value == 2,
				, //elif
					value == 3,
