chris_dennis
How do I name a table script saved to a Journal using comand inside a script?
// current line is
CYT << Save Script for All Objects To Data Table;
SOOC << Save Script to Journal;
Result in journal is "new table"  I want to give it a better name like "my table"
chris_dennis
Re: How do I name a table script saved to a Journal using comand inside a script?
This worked, thanks for the help and suggestions.
Byron_JMP
Chris,
Before saving the script to the table, try renaming the data table.
dt=new table();
dt<<set name("test");
dt<< save script to journal;
Cheers,
Byron
JMP Systems Engineer, Pharm and BioPharm Sciences
chris_dennis
Running the suggestion results in same “New Table”.
Any other suggestions?
Thanks, Chris
ms
Super User ms
dt = New Table();
dt << save script to journal;
Current Journal()[Button Box( 1 )] << set button name( "My table" );
chris_dennis
